Konica Minolta 1050E with SC36-06, changed TH3 and TS2 can't get rid of code
[Error Code]
Replaced TH3 and TS2, Turn on service mode and it shows 3-0 not 3-1, doesn't matter what I change it to it still throws the code. Kida stuck at this point, any help would be appreciated.
Re: Konica Minolta 1050E with SC36-06, changed TH3 and TS2 can't get rid of code
Thank you,
Dave
Check the I / O check if the thermistors are measuring correctly.Make sure the heat sinks are open.
Check switch DIPSW 03-1 = off
Check behind the ACDB, electrical components that cause fuser error codes.
Thank you,
Dave
Check fuser back conector for any dmg. Also there might be a fuse blown on your acdb or prcb. You can check all fuses for continuity with a mutimeter. Those fuses are noted with ICP on the board.
