On the new 8 series we are finding that when setting up SSL (for 3rd party app like Output Manager), that a setting under Network/TCP Socket settings is missing. The particular setting is SSL(ASCII). Although this is usually checked by default, with the new devices, the setting is just gone. This is causing DRS to give a "unable to connect" message when pushing the client or authentication. I know this is the problem because when I played around with firmware, function versions, data and system initializations for about 2 hours, some combo of these changes put the setting back and DRS was able to connect. I'm wondering if anyone else has seen this and found either a better way or soft switch setting to get this setting back. I did another 458 yesterday and we had the same issue. This missing setting does not seem to affect Equitrac, or Autostore (when using the combined client and DRS). 8 series that have been in place for about 6 months show all 3 choices in the TCP Socket settings so I'm pretty sure it's firmware/function version related. Seems to be affecting only new placements with the latest firmware on them (Q4). I have attached an image of the usual page and the difference.
TIA, Emujo
TIA, Emujo
