BIZHUB C3350
  • antone
    • Oct 2014
    • 344
    BIZHUB C3350
    Paper trays say no paper ....but when you send a job or copies it picks up paper from both trays and works.
    Sent from my SM-N920V using Tapatalk
  • habik
    • 2013
    Re: BIZHUB C3350
    Firmware
    Trouble reset
    PE sensor I/O check
    Sent from my Mi A1 using Tapatalk
    Firmwares HERE
      • 22999
      Re: BIZHUB C3350
      What exactly does the screen say, and in what context?
      "Load Paper" can mean that you haven't loaded the correct media type or correct media size to match the print driver request. It can mean that it is incorrectly identifying the original size. It can mean that it is incorrectly identifying the paper tray paper size.
      • antone
        • Oct 2014
        • 344
        Re: BIZHUB C3350
        Originally posted by habik
        Firmware
        Trouble reset
        PE sensor I/O check
        Paper empty
          • 22999
          Re: BIZHUB C3350
          I seem to recall that that machine comes with some strange defaults out of the box, like bypass tray as the default paper source. =^..^=
