i have a c7000 machine if you print 100 sheets it will duplex okay.
if you print a longer run maybe 500 sheets, within the 500 sheets there will be random sheets where the duplexing is off, drifts randomly 5mm.
i believe it is a mechanical issue. and it is only on the duplexed side. registration for simplex is fine.
what should i be doing. some check list to systematically figure out what needs to be changed would be very welcome.
