Issue with requesting a Certificate of Authority (CA)
  • Mugz2016
    • Jun 2025
    I am trying to request a CA on the Konica C368. The issue I am having is when I request the certificate it assigns the common name as the IP and this grayed out. It will not allow you to change this. In my job we need to submit a form with the FQDN/common name and does not accept the IP as a FQDN/common name...it will get rejected. Is there anyway to change the common name to something like xxxxxxxxxx.com?
    Thanks in advance for your help!
  • B0265
    • Jan 2007
    • 718
    Re: Issue with requesting a Certificate of Authority (CA)
    It should be possible from firmware version G00-N5:
    Availability of the function for changing the Common Name to IP address. (bit1)
    Software SW No. 107 0x00: Disable (Default)
    Software SW No. 107 0x02: Enable
