Konica Minolta C284e Firmware
  • mearmi
    • Oct 2010
    • 346
    [Misc] Konica Minolta C284e Firmware
    Hi everyone
    looking for Konica Minolta c284e Firware G20-J6.
    Please advise if someone can send me. Will b a great help.
    Thanks a lot
    mearmi@hotmail.com
  • Zesti
    • Jun 2009
    • 308
    Re: Konica Minolta C284e Firmware
    What problem you are facing? pl. describe.
    • mearmi
      • Oct 2010
      • 346
      Thanks for your replying. Client needs to get AirPrint
      • Synthohol
        Certified Konica Expert
        • 5740
        the latest M1 FW supports airprint.
        • tech51
          • 846
          • Synthohol
            • 5740
            Good reminder I forget most people don't read the read me file
            • mearmi
              • Oct 2010
              • 346
              Can u please send me
              mearmi@hotmail.com
              • dherhut
                • Oct 2018
                • 7
                Hello, I recently had to change the MFPB for a Konica Minolta Bizhub c284e, but I need the firmware (G20-J9) I could not get it and the machine still does not work.
                Could you help me with this? If it is necessary to cancel by the firmware, indicate me the value and as payment.
                Thank you
                dherhut@yahoo.es
                • dherhut
                  • Oct 2018
                  • 7
                  I have tried to install the firmware according to the instructions of the technical manual of the machine, but it has not been possible for me. I do not read the pendrive, I have tried several and the closest to the firmware update is that the format is not correct .... Change the MFP, because it threw the error c 6901. with the new MFP throws the same error. I have tried everything and I can not get the machine to work. Any suggestions?
                  Thank you
                  • Synthohol
                    • 5740
                    ok first off, the 6901 code is for the dual scan board you mount to the mfp board.
                    is it good?
                    put the old mfp back and leave the dual scan board off and unplug the doc feeder other wires.
                    if no codes and you can make copies there is your issue i think.
                    the code is for
                    DSC board mount failure 1
                    Trouble code C6901
                    Rank C
                    Detection timing When MFP detects that DSC board/1 (front side) is not properly installed.
                    did you swap to a single sided feeder?
                    is the right feeder selected in service mode?
                    details please why change the MFP board for the DSC issue? especially if the code comes right back with the new MFP?
                    also M1 is the firmware you want, J9 is hella old.
                    • dherhut
                      • Oct 2018
                      • 7
                      Dear, it is true what you tell me but the konica technician in a previous review detected the following: "This error code is associated with DSCB-1 card, which controls the scanner and ADF of the equipment, which in the In addition, the machine has another error code that is C-D262, which refers to a wi-fi card model UK-208, which as in the previous case, this machine does not have .
                      It should be noted therefore that having made the corresponding field tests, such as reset error codes and physical verification of components, it can be concluded that the main card is with logical damage, which caused the team to behave erratically and without being able to perform any function.
                      In conclusion, the damages described above are apparently attributable to sudden drops and increases in voltages in the electrical network where the equipment is connected. "
                      Logically, the repair offered by the service was extremely expensive (USD $ 6,000) only for the change of the plate, which I found on eBay at less than $ 500 USD, but I could not install it on firmware ... I'll keep trying, if I have any other suggestion I would appreciate it
                      regard
                      • dherhut
                        • Oct 2018
                        • 7
                        Is there someone who can help me ???
                        • dherhut
                          • Oct 2018
                          • 7
                          is it good?
                          the code is for
                          Trouble code C6901
                          Rank C
                          dear .. I've really kept trying, I did what you recommended and nothing ... I reinstalled the new board and I still do not solve the problem .... you who are expert in these issues that another option I have ??? I'd appreciate your help.
                          • mhmds102466
                            • Jul 2019
                            • 74
                            [QUOTE = Zesti؛ 705427] ما المشكلة التي تواجهها؟ رر. وصف. [/ QUOTE]
                            How are you? I have a Bizhub c284eShow on screen
                            serial number must be entered contact your service representaive
                            • mhmds102466
                              • Jul 2019
                              • 74
