Insert the correct Imaging Unit
  • Babangida
    • May 2025
    [Error Code] Insert the correct Imaging Unit
    Hello everyone. I have Konica Minolta CF2002 that says Insert Correct Imaging Unit and close the door. I bought the IU chips several times from different vendors but non worked. I read somewhere that it is the firmware I need to upgrade. I dont even know what or where the firmware is or how to upgrade it. Any help on how to come about this will be highly appreciated. Thanks
  • Bix
    • Apr 2018
    • 1421
    Re: Insert the correct Imaging Unit
    Hi,
    you can download the FW from the KM's website. You need the access as technician
    • Babangida
      Originally posted by Bix
      Hi,
      Thank you so much. As I am not a technician, i doubt if i will be granted access. there may be another way. I pray that someone in this forum might have come across this or similar problem in the past that will kindly share his solution with me. Thank you as i patiently wait for guidance.
      • Synthohol
        Certified Konica Expert
        • 5740
        not to be a wise ass but you could try an OEM IU?
        • Toxic
          • 694
          I dont think firmware will resolve your problem.
