copier called in for load popping noise....troubleshooting I found broken fuser gears. one was a one way gear broke in two then the big thick drown gear was worn down also the gear against that one with two different teeth sets on it. only ordered one set of all these and when I brought the machine back up it stripped the gears again. Is there something going on? Has anyone else had this problem?
copierfixer
copierfixer
