Maximum print area bizhub c454
  • Medbak
    • Feb 2019
    • 3
    Hello everyone, I have a printer konica minolta bizhub c454, I would like to know how to print an area greater than 302mm width in a sheet of 320mm?
    I know a technician who managed to do that, he changed some parameters, please help me if you know a solution
    Bests regards
  • Synthohol
    Certified Konica Expert
    • 5738
    Re: Maximum print area bizhub c454
    there is always an edge erase or you ask for fuser jams.
    wait, 320mm, thats 12.5" if you want 12x18 full bleed print on 13x19 and trim?
    • Medbak
      • Feb 2019
      • 3
      thanks for your answer, i would like a maximum Image area on a 320mm sheet, Because you can not in the standard exceed 302mm on 457,2mm
        not even with custom size setting and full bleed? (not recommended)
        your service manual should cover that issue.
        • Medbak
          • Feb 2019
          • 3
          do you have a method to do that?
          • allan
            RTFM!!
            • 5459
            Need to set to custom size and use bypass i think.
            Also done it before but on a C452.
            Also try the "S" sizes like A3S
            Whatever
