Konica C545 Bypass tray paper jam
  • kobi gabay
    • Apr 2016
    • 20
    [Jamming] Konica C545 Bypass tray paper jam
    Hi guys.
    I have a problem with this model when I'm tried to print or copy on heavy paper 300 gram He always jams on the first page!! tries to pickup and failed every page 🤔🤔🤔🤔 Plain paper or 180-200 grams works fine!!!!
    New clutch/pickup roller/separation roller /setting👌
    Need your help and knowledge...
    Thanks in advance😊
    Re: Konica C545 Bypass tray paper jam
    Originally posted by kobi gabay
    Hi guys.
    Thanks in advance😊
    what are the paper trays set on for weight of media?
    • kobi gabay
      • Apr 2016
      • 20
      Thenks for the quick replay🙏
      My English is not so good and I hope that I Understand your question.....
      All the trays with plain A3/A4 and the bypass is set to thick 4 A4 when 300g is loaded.
      • tsbservice
        Field tech
        • 7925
        To my limited knowledge there isn't such a model in existence. Did you mean C554?
        There is separation roller pressure adjustment for thick paper in SM, especially for 300g/m^2.
        • kobi gabay
          • Apr 2016
          • 20
          You are right I made a mistake in the model number.
          I will look for it in the SM .
          Thenks for your help guys🙏🙏🙏🙏🙏
          • kobi gabay
            • Apr 2016
            • 20
            I tried to look in the SM and didn't find noting about separation roller pressure adjustment I Will appreciate if you can �� the instructions for it ����������������
            • tsbservice
              Field tech
              • 7925
              There's a spring to play with, bad screenshot but once you see it you will get an idea.
              • kobi gabay
                • Apr 2016
                • 20
                Thanks very much
