how to active web browser C284e
  • ck1
    • 485
    Hi, i have the UK-204 , may i know how to enable the funtion web browser ? what the funtion code ? thanks
  • rrrohan
    • Sep 2011
    • 1977
    Re: how to active web browser C284e
    Did you buy the LK104 as well
    • ck1
      • 485
      No , you need to LK unit too ?
      • Synthohol
        Certified Konica Expert
        • 5738
        you dont need a function code, just enable it. it will go through the internet and license itself.
        • rrrohan
          • Sep 2011
          • 1977
          your thinking of 8 series or above.
          4 series needs both the UK and LK
          • Synthohol
            • 5738
            oh crap, the LK-101 v3
            sorry, been so long i totally forgot.
            • emujo2
              • Mar 2017
              • 1580
              Agree, also you have to install the web browser firmware..G20-XXX. Won't funtion w/o it. I just had a C364e customer ask for this. The LK license was $50 his cost. Not to bad in the land of MFP options. Once you have the memory and firmware up to date you can activate the code from the control panel (assuming the MFP can get to the outside world internet) Service Mode/Billing/License Mgmt...Activation/Token Code/ enter token code. If the MFP is blocked, then you have to use KM's LMS server to generate a license code and function code. E
              • Synthohol
                • 5738
                Originally posted by Edward829
                Tires need to be inflated to the right pressure to be able to handle the weight of the car, road conditions, and temperature. They also need to be inflated at the right pressure to be able to drive the car at top speeds. Overinflated tires are less efficient and can lead to uneven wear and tear on the tires which also decreases the overall life of the tires. fuckthisguy.com
                your family must be so proud of your accomplishments huh?
                • tsbservice
                  Field tech
                  • 7923
                  Haha, double damage
                  Damn I wish I could be so go od
