Bizhub c364
  • smiley
    • Aug 2008
    • 615
    Bizhub c364
    Good day guys i have a problem with this machine evrytime i perform gradiation proces it always says sub scanning ng even i do it in a3 or a4 size. I already clean the scanner unit.
    there is no glory without sacrifice
  • rrrohan
    • Sep 2011
    • 1977
    Re: Bizhub c364
    what about non image area erase
    ive also had the frame of scanner bent cause issues like this
    • copyman
      Owner / Technician
      • Sep 2005
      • 4692
      Re: Bizhub c364
      Did you clean the 2 transport belt IDC sensors? Or if any of the IU's are over life or just bad.
      • smiley
        • Aug 2008
        • 615
        Re: Bizhub c364
        All 4 drum unit are new. It only happen when i replace the drum unit. The scanner unit are in perfect shape. Iwill try to clean idc sensor and update if this will correct the problem. Thanks for the help guys.
