c4641
  • E-ring
    • Apr 2019
    • 10
    [Error Code] c4641
    hi
    We have a Develop Ineo+ 2060L here that gives us some trouble:
    C4641, C4642, C4643 (and a few 4631, 4632, 4633)
    It appears only after printing, when the printer does the self adjustment, or when color registration auto adj. is made manually (after printing)
    After a restart, color registration auto adj. finishs normally, several times.
    We tried solenoid, Transferbelt and returning to install data.
    Thanks for suggestions...
  • tsbservice
    Field tech
    • 7923
    Re: c4641
    If color registration shutter solenoid is not failing it may be PRCB...is my guess.
    Btw, nice user name and picture
    • E-ring
      • Apr 2019
      • 10
      Re: c4641
      Thanks!
      One of my colleagues remembered a similar case... FW had a bug, so I will try that next.
      • tsbservice
        Field tech
        • 7923
        Re: c4641
        Doing FW won't hurt. Good luck.
        • E-ring
          • Apr 2019
          • 10
          Re: c4641
          It is a FW bug!
          Everything newer than the G00 that was installed will solve it.
          • E-ring
            • Apr 2019
            • 10
            Re: c4641
            Originally posted by E-ring
            It is a FW bug!
            So, in the end it was not the mass production FW that solved it, its a bug fixing one gmf21. You have to search for C4661, all the other errors I had are not mentioned.
            Whole trouble was caused by customer choosing Toner save in each tray setup (cheap f...).
            I guess, printer uses low density only in adjustments outside of tech mode.
            • Amine
              • Nov 2020
              • 1
              Re: c4641
              i dont understand the solution i have the same problem
              please you can explain
