Bizhub c3350 failed to start ?
  • mrfuser
    • 1603
    First time see this. Anyone know what is failing?
    Re: Bizhub c3350 failed to start ?
    actual ERROR CODE?
    • mrfuser
      • 1603
      actual ERROR CODE?
      • copiertec
        • Jan 2016
        • 2186
        Is the scanner moving at start up? If not check the scanner belt to see if it's broken.
        • tech51
          • 846
          The only time I had this, replacing the ssd board on the mfp fixed it.
