KONICA C454e CE PASSWORD RESET TO DEFAULT WITHOUT CHANGING THE SSD
  • SMARTENGCENTER
    • May 2020
    • 22
    [Misc] KONICA C454e CE PASSWORD RESET TO DEFAULT WITHOUT CHANGING THE SSD
    Hi Friends.
    Hope you all doing well.
    I want to know the procedure of konica C454e machine CE password reset without changing the SSD any solution?
  • Synthohol
    Certified Konica Expert
    • 5738
    Re: KONICA C454e CE PASSWORD RESET TO DEFAULT WITHOUT CHANGING THE SSD
    change it in service mode ex security menu.
    • SMARTENGCENTER
      • May 2020
      • 22
      Dear i cannot access the service mode there is already CE password in the machine which i dont know so i want to enter in service mode without changing the SSD i heard that there is some REST tool of konice some file that reset the CE password and admin password too that make copier to default some procedure like we do firmware of copier is it true?
        are you not a trained KM tech? do you not have the manual?
        • SMARTENGCENTER
          • May 2020
          • 22
          yes i am.
          but i dont have that file to reset the CE password.
          i have only FW.
          • SMARTENGCENTER
            • May 2020
            • 22
            i dont have service manual of C454e.
              yes i am.
              i have only FW.
              IF you are a trained KM tech you SHOULD have access to the website .. everything you need is there.
              • SMARTENGCENTER
                • May 2020
                • 22
                Friend i have worked with KM long time before
                so no more access
                any solution?
                • Synthohol
                  • 5738
                  did you try 9272 twice instead of 4 times?
                    hell he doesn't even have a manual for this model....
                    • SMARTENGCENTER
                      • May 2020
                      • 22
                      Friend i have tried everything 9272927292729272 actually machine counter is 20k and someone changed the CE password and admin password too.
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        On Konica engineers site they do a mfp reset tool best to call a current credited service engineer good luck
                        Regards Mark
                        • SMARTENGCENTER
                          • May 2020
                          • 22
                          Friend i dont see manual a lot while repairing machines mostly i know the codes of the machines and sometimes when i stuck then i see manual of 364e black and white machine because 4 series many models codes are same like 224,284,364,454,554
                          btw i have been working with KM for more then 8 years
                          • SMARTENGCENTER
                            • May 2020
                            • 22
                            ANY LINK?
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              ANY LINK?
                              Sorry no this is only available to trained engineers if you look around on some other threads or place a new thread in service manuals someone may help you
                              Regards Mark
