konica c224 scan ftp in nas
  • lucycopy
    • Jan 2019
    • 22
    good evening everyone I wanted to know what was the right syntax to set up an ftp in a nas in a konica minolta c224 series the folder has this address \ vol_1 \ scan
    host addres: ip address of the nas
    File path ?? (\ Vol_1 \ scan) ??
    • 27061
    Re: konica c224 scan ftp in nas
    The file path syntax requires a forward back-slash (/) and any additional sub-folders also require
    a forward slash (/) as a separator.
    • SMB: \\host name\folder
    • FTP: ftp://host name/folder name
    Most likley its scanning SMB to the NAS if it stop working
    Could be do to an update on the NAS as smb1.0 has been disabled on most system updates
    Scanning smb would be the other
    • lucycopy
      • Jan 2019
      • 22
      thanks
      in nas the scan was ftp not smb
      so in file path I write? // vol_1 / scan?
      • Bix
        • Apr 2018
        • 1421
        Front slesh is not mandatory in Konica Minolta
        • enricocopyline
          • Jun 2018
          • 100
          in a konica c353 after the logical formatting of the hard disk I can no longer make it work
          what can it depend on?
          ftp on a normal pc works
          • Synthohol
            Certified Konica Expert
            • 5249
            make sure the HDD shows as "installed"
            turn off enhanced security if enabled because that blocks FTP use.
            [edit]
            Question
            How to enable the input of an underscore character in the FTP and SMB Host Name fields.
            Answer
            Special firmware versions are available to support the underscore character for FTP and SMB Host Names.
            • Monochrome
            bizhub 223/283/363/423: Use version GSB-D1 (replaces version GE8-B5 that was for FTP only) is available
            • Color
            bizhub C224/C284/C364: Use version GS8-65
            bizhub C454/C554: Use version GS8-65
            bizhub C654/C754: Use version GS8-65
            After installing the special firmware, software DIPSW 44 must be set to Hex 20 or 00100000 binary.
            To change the DIPSw setting in Service Mode:
            1. Touch [Software Switch Setting].
            2. Touch [Switch No.] and enter the intended switch number with the ten-key pad.
            Software Switch No.: 44
            3. Touch [Bit Assignment].
            4. Use [?] or [?] to select a bit. To set the bit, enter 0 or 1 with the ten-key pad.
            5. To set the bit in Hex, touch [HEX Assignment] and use the ten-key pad and [A] to [F]
            keys to enter numbers and characters.
            HEX Assignment: 00 g No Underscore support
            HEX Assignment: 20 g Enables the Underscore character for FTP and SMB Host Name fields
            6. Touch [Fix].
            Notes:
            a. The Special firmware and Release Notes are available via the Konica Minolta Download Selector and One-Stop Product Support.
            b. This firmware does not support the underscore character for PageScope Data Administrator or OpenAPI.
            c. When the Software Switch No.44 is set to 0x20, the underscore character can be input for SMB host name in the following settings:
            • Direct input of the destination for Scan to SMB and Scan to FTP
            • One-touch destination for Scan to SMB and Scan to FTP (It is also supported when using PSWC.)
            • Image Log Transfer (Type2) settings
            • PING Host Address field to help when troubleshooting
            d. The underscore character cannot be input in the beginning and ending of the host name. For example, the host names as follows are invalid.
            SMBhost_
            _SMBhost
            _SMBhost_
            [/edit]
              • 22809
              completely out of context for this thread....
              go start your own new thread listing all steps taken... parts replaced ... parts counts.
              mind what thread you are posting in.
              • emujo2
                • Mar 2017
                • 1580
                And then he rips the guy int he new thread..lol
                • enricocopyline
                  • Jun 2018
                  • 100
                  [edit]
                  Question
                  Answer
                  • Monochrome
                  • Color
                  6. Touch [Fix].
                  Notes:
                  SMBhost_
                  _SMBhost
                  _SMBhost_
                  [/edit]
                  can there be the problem of scans with - (minus) instead of with _ (undersore) in host name? In SMB? in konica c224
                  • Synthohol
                    • 5249
                    You can only try and see.
                    If it fails try the host IP instead. That's the simple solution.
