Konica Minolta Bizhub C364e slit scan glass clean error.
  • Alex1
    • Oct 2012
    • 285
    Does anyone know how to turn off thus feature in the menue?
  • tsbservice
    Field tech
    • 7926
    Re: Konica Minolta Bizhub C364e slit scan glass clean error.
    Service mode - Machine - ADF Scan Glass Contamination - Not Set
    • Alex1
      • Oct 2012
      • 285
      Thank you. I remembered where to find it. Thanks for your response.
      • KMFLT3CH
        • May 2017
        • 217
        Minor correction, to turn the feature off it's actually located under System 2, not Machine.
        The setting under Machine is to manually check for stains on the front or rear slit glass.
        The setting under System 2 is to disable the check from occurring entirely (from opening/closing ADF cover, coming out of sleep mode, etc.)
        To disable the checking entirely: [Service Mode] -> [System 2] -> [ADF Scan Glass Contamin. Set.] -> [Not Set] for front and back side.
        And another note, on newer models (and older models with newer firmware version) they changed the name of this feature:
        ADF Scan Glass Contamination --> Split Line Prior Detection
        ADF Scan Glass Contamin. Set. --> Split Line Detection Setting
        • tsbservice
          Field tech
          • 7926
          KMFLT3CH, You're right thanks for that clarification much appreciated.
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            Quite often this issue can result from the timing of the cleaning brush being incorrect.
            IF its parking at any other position than where its fully white it will cause this error. The little belts also end up very loose allowing this problem to come back too. Retiming the brush is dead simple.
            • Alex1
              • Oct 2012
              • 285
              Yes that was the case. Thank you for your help
