C224e - SMB scan failed to connect to serverq
  • c3110
    • Jun 2019
    • 16
    [Misc] C224e - SMB scan failed to connect to serverq
    Hi,
    I'm struggling with a C224e in setting up SMB scan entries. Devices are Windows 10 PCs, shared folder set up with user everyone, full read and write access, no AD but a simple workgroup in a LAN. I tried several combinations but none work, all are throwing errors about connecting to the server. I made sure the IP and DNS entries are correct, SMB 1 and 2 is on, printing works fine and scanning to FTP on some Win7 and even one W10 machine works with the FTP Utility.
    I tried with both IP and Hostname. Tried path as "SCANS", "/SCANS", "//desktop1/SCANS". As username I typed everyone and nothing on password, maybe this is where it fails?
    Sharing works just fine, folder is accessible and anyone can create files.
    Anyone struggled with SMB scanning on Windows 10?
    • 14153
    Re: C224e - SMB scan failed to connect to serverq
    Originally posted by c3110
    Hi,
    I think I would set a password and see if that corrects the problem.
    Growth is found only in adversity.
      • 22810
      Hi,
      win10 causes all sorts of problems... I would suggest if Win10 hasn't disabled SMB 1 to do so because of security concerns
        • 26736
        should be\\ ip address\scans
        for smb
        ftp would be the way you had it. /
        the slash matters
        You didn't need the two \\ on Konica it will add them
        Windows 10 you will need a user password for smb
          • 12499
          If the client's PC is password protected you need to use those credentials. If not password protected do no fill in authentication fields.
          I always create a folder on C and name it Scans then in the scan path field use "Scans" no slashes.
          If this does not work I will then, with the customer's approval, create a new user that is password protected and has admin rights and use those credentials. That almost always works.
          If using hostname it needs to be all caps.
            • 14153
            Yep. I always like to create a new user simply because the customers will change their password and then they can't scan to folder.
            • tsbservice
              Field tech
              • 7389
              You must enter user name and password. User have to have read/write rights on folder. As a path you will need only "SCANS".
              • Firmaware
                • 30
                Win 10 doesn't support SMB 1.0, so Fw must be GDL-M1 and nucht standard
                Gesendet von meinem SM-G980F mit Tapatalk
                • copier tech
                  • 7730
                  Hi,
                  You need to have a password set with Win 10.
                  If you are setting up via the copier use the reference button this will allow you to browse your network, find your PC log in, find your SCANS folder, then save in to the address book.
                  If you are manually entering the folder path you don't add the backlash \ etc (But looks like you are using a forward slash anyway!?)
                  • and
                    • Oct 2011
                    • 83
                    With GDF-M1 Firmware that support SMB2.0
                    There was a phenomenon in which ScanToSMB cannot be used without a password in the customer's device with the latest firmware.
                    The function in which SMB version of SMB client function can support only SMB2.0 (bit2)
                    DipSW No.219 0x00: SMB1.0/2.0 (Default)
