BH-364e mono, what options needed for searchable PDF/A?
  • Hansoon
    • Sep 2007
    • 3237
    Guys, what options are needed to upgrade a bizhub364e mono machine to produce scans with searchable PDF/A?
    Hans
    " Sent from my Intel 80286 using MS-DOS 2.0 "
  • tsbservice
    Field tech
    • 7389
    Re: BH-364e mono, what options needed for searchable PDF/A?
    For Searchable PDF you will need UK-204 and LK-105 v3.
    • allan
      RTFM!!
      • 5402
      Have not messed with this in years.
      Any improvement on the processing speed?
      Does it practically work? In the beginning of this i tried to set one up for a document storage company.
      It was not up to scratch, there desktop scanners and software worked fast but the KM could not keep up.
      Whatever
      • Synthohol
        Certified Konica Expert
        • 5168
        Forgive me if I'm wrong because I also work on kyocera, I thought pdf/a is a compressed pdf and unreadable by any ocr app?
        Searchable scanning will take longer because it goes through the or process on the machine instead of using a free copy of omnipage to ocr faster.
        Good luck either way
        If you need the dictionary file just send me a pm and I will get it to you sir.
