Presence lag on New Series 8
  • Bix
    • Apr 2018
    • 1421
    hi I have currently encountered this problem on two new printers that come from the factory with G00-X4 firmware.
    After setup and a few minutes, the display is no longer responsive. Some parts of the display appear as though the touch is faulty. Even after switching off and on again. This happened to me a few months ago on a Bizhub 227 and now on a bizhub 308e.
    In the bizhub 227 printer I tried a firmware update without success. I solved it by clearing all data. After the reset, the operator panel started working perfectly. I haven't tried it on 308e yet but the problem will probably be the same.
    This does not happen on all printers but only on some new ones with G00-X4 factory firmware. Let me know if anyone has had the same experience as me.
  • femaster
    • May 2011
    • 1466
    Re: Presence lag on New Series 8
    Have you tried the touch panel calibration? I'm not sure if method (a) below applies to the 8-series machines or not, but I know the method (b)(a) Panel Calibration by using USB memory(b) Panel Calibration by manual operation
    1. Press [Menu] -> [Counter] -> [Display Keypad].
    2. Press Stop -> Clear -> 1 -> 1 -> 6 -> 6 -> Start key, then calibration starts.
    3. After 30 seconds, turn OFF the main power switch.
