Konica c6500, job waiting
  • Rohullah
    • Sep 2019
    • 37
    Hi everyone
    My konica c6500 have a problem, when i send to print, it doesn't process or print, it shows print waiting or rip waiting.also does not print controller test pages. Printer is ready, server is okay, fiery is connected, it can print old proccesed files but not any new file.
    Thanks in advance for your help.Screenshot_20210125-005416_Gallery.jpg20210125_004912.jpg
    Re: Konica c6500, job waiting
    Originally posted by Rohullah
    Hi everyone
    Thanks in advance for your help.[ATTACH=CONFIG]48011[/ATTACH][ATTACH=CONFIG]48010[/ATTACH]
    check error log
    turn the machine off disconnect any options.
    reboot
    any errors?
    when did this problem first appear?
    • Synthohol
      Certified Konica Expert
      • 5839
      i know it sounds silly but check the default paper size config of the controller and make sure its metric A4/A3 not letter.
      that would cause it to hang if the test page default size is set to US size letter/11x17
      check command workstation!
        good catch brother
        • Rohullah
          • Sep 2019
          • 37
          [QUOTE=Phil B.;1670748] No errors, the machine was off for few weeks because of fuser belt, yesterday i got new belt and installed that and this problem found.
          Also it does not print any controller test pages
            [QUOTE=Rohullah;1670965]
            go back over your work ...if it was working before you touched it and not after the you have a T.I.P. technician induced problem.
            • Rohullah
              • Sep 2019
              • 37
              [QUOTE=Phil B.;1671291]
              Hello again
              As i searched, problem is from hard drive. But I don't know how to install fiery 408 v2 on a new hard drive. Could you please help
              • Rohullah
                • Sep 2019
                • 37
                Hi and thanks for replying
                I found the problem is hard drive, but i dont know how to install ic 408 on new hard drive, should i install a windows on new hard drive and install driver on it or maybe by usb. If you have any manual about this or you can help, it will be very helpful ๐Ÿ™
                • Synthohol
                  • 5839
                  Cant be harddrive if the fiery shows 00 and accepts jobs.
                  That's very unusual.
                  What did it say in command workstation?
                  • Rohullah
                    • Sep 2019
                    • 37
                    Commond work station connects to server, when sending print, printer not receive Data.
                    I say its hard drive because i have also a hard drive with IC 409, i have installed that and printer received the job, than miss printed
                    • Synthohol
                      • 5839
                      Failed jobs are pink in command workstation. Click one and read the error.
                      • Rohullah
                        • Sep 2019
                        • 37
                        Hi guys
                        The problem solved
                        It was HDD problem, mean while server was 00 but hdd had problem, i installed hdd as external hdd to a computer and run bad sector fixer on it, than installed on server, now its working normally.
                        ๐Ÿ˜‰
