I have a Di350 when installing the module for duplex she jammed in the fuser output, please someone help me, thank you.
Di350 duplex
On a Minolta 250, 251, 350 or 351, when you put a duplexer on the machine, the machine uses the small motor in the duplexer to drive the fuser. The motor is at the top, inside the duplex unit and has most likely gone bad. If you take the duplexer off of the machine, and it stops jamming, then the problem is the motor.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
I've also had the PCB's fail in the duplexer. Best bet is probably to swap the duplex unit out with another one before ordering parts.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
Hi on the DI350 duplex is a option, so if you fit a duplex you have to remove a piece of tape covering the exit from the fuser where the paper would enter the duplex,
it's about 10 inchs long and quarter of a inch wide and the same colour as the machine covers so you need to look closely,GGComment
We had Duplex units causing the fuser roller drive to stop for unknown reasons, maybe weak motor, perhaps gears or fuser roller bushings binding a little more than usual, maybe a bit of all together. However by changing the Duplex Unit it was most of the time solved.
Hans“ Sent from my Intel 80286 using MS-DOS 2.0“
https://www.copytechnet.com/images/smilies/biggrin.pngComment
healpe
Don't know in the rest of the world but in our region the Di-350 came complete with Duplex Unit. Only the Di-250 needed this as an option.
Hans
I NEED TO KNOW THE SPECIFICATIONS
BEST TECHNICIAN . NICE PEOPLE .Comment
My friend Zaza excuse me, I did not understand you, but I do not speak English, I use a translator to communicate me.
hi friend
hi friend silvio it's not probleme you are my friend technicianand l need open with you a new friend chip relation ...you and me and more other friend technician in this site need to collaborate together to helpfulness for anything in copiers machine . so nice to meet you my friend silvio .
