Duplex printing on C3320i no more available on Mac os
  • olivenoire
    • May 2021
    • 38
    Hello,
    Probably since driver update and for unknown reason, we are no more able to select duplex option on Mac OS. (11.5)
    The printer print "duplex" on 2 side by default.
    Is there any option in admin mode ?
    Or by design there is a limitation on Mac OS driver?
    regards,
  • Synthohol
    Certified Konica Expert
    • 5740
    Re: Duplex printing on C3320i no more available on Mac os
    CUPS is where you fix that.
    How to enable CUPs web interface – Timely
    • olivenoire
      • May 2021
      • 38
      TY, will give a try. Does it allow to print 1 side or 2 sides?
      Meanwhile, I've download the driver and found the file "IT6PSMACOS_223AMU.txt" in the package. It seems there is some severe limitations on Mac OS.
      • Synthohol
        • 5740
        the CUPS is like windows printer preference defaults. you specify single side by default and the driver allows either simplex or duplex.
        • olivenoire
          • May 2021
          • 38
          Sounds great.
          Anybody to feed back to Konica - Minolta that's so strange it does not manage duplex by default on Mac OS ?
          • Synthohol
            • 5740
            Every copier after the 3 series has duplex by default written in the driver. It's part of the "green" initiative to save paper.
            While in CUPS click on the printer and set the default option to 1 sided and you should have the choice in layout or finishing.
            • olivenoire
              • May 2021
              • 38
              Okay. Now I understand.
              But this printer let the fan turning (with noise) even in sleep mode (I measured 9W). Some kind of contradiction.
              Anyway I will try this setup. Thanks again.
              • olivenoire
                • May 2021
                • 38
                Update :
                I've succeed to print one side (recto). Thats fine.
                But I can't even select 2 sided print.
                This option is always not available.
                is there a simple way to decide either to print 1 sided or 2 sided using a Mac?
                I can't understand what is going on
                • Synthohol
                  • 5740
                  it depends on the application i think. i ALWAYS use the printer properties box and not the application to set my options.
                  ive found when both the app and printer properties say duplex, they cancel each other out.
                  • olivenoire
                    • May 2021
                    • 38
                    That's what I thought at first.
                    But as soon I select the Ricoh, 2 sided is deactivated. No problem using Ricoh IM C3000. This allow to print 1 sided or 2 sided.
                    Seems there is a limitation by the driver. Shame on Ricoh.
