Calibration sheets jamming in finisher
  • exify
    • Jul 2025
    I can't figure out why... any insight?
    It's a Creo, and it's printing sheets for color calibration. It does it 100% of the time.
  • Reyes2424
    CREO
    You have to check that the CREO knows which finishers are on. You also might want to check and see if there has been any updates recently performed to the CREO. You may have to check your settings.
    Good Luck
    • exify
      its a c6500, and it knows the finishers, all updates are there.
      • stathistec
        • Nov 2008
        • 17
        try to print in a different paper size ( A4 A3 13x19)
        the creo is V2?
        • random
          what is the code?
          • exify
            the creo is V2?
            same thing on all sizes
            creo is v2 but it happened on v1 too i believe
            random: 72-22
            • kmcopier
              PSP
              • Oct 2008
              • 183
              remove the finisher and print is again. also remove the finisher in preference.
              Check if it works then then you can forget the finsher as a problem
              also you can set to switch paper 11X17 13X19 A4-A3.
