c258 toner spreading/dropping onto psu glass
  • Scarekrow
    • Feb 2012
    • 80
    Hi,
    I have had this problem on a few machines, I thought it might be the katun toner, Im using "business colour" and have only used this, machines have done 150k colour upwards, however there is a part of the dev unit that connects to a ducting system at the back of the machine to check, does anyone know which fan drives this, and if it's common for it to get blocked, and if there is an easy fix.
    Thanks.
  • tsbservice
    Field tech
    • 7924
    Re: c258 toner spreading/dropping onto psu glass
    At 150+ color clicks and using Katun colour toners you've been asking for troubles long time ago.
    Not easy to get out there without replacement of expensive color developer units or at least converting K into colour ones.
    • Scarekrow
      • Feb 2012
      • 80
      [QUOTE=tsbservice;2092625]At 150+ color clicks and using Katun colour toners you've been asking for troubles long time ago.
      Not easy to get out there without replacement of expensive color developer units or at least converting K into colour ones.[/QUOTE
      It seems to effect one colour in most cases usually the cyan, if it was the toner, wouldn't all the colours drop toner in the same way?
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        This is a C258 like your title says?
        Sounds like a 4/4e series from your description of the issue, if it's only cyan.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • Scarekrow
          • Feb 2012
          • 80
          C258
          • Synthohol
            Certified Konica Expert
            • 5740
            here ya go!
            hope it helps
            • Scarekrow
              • Feb 2012
              • 80
              Originally posted by Synthohol
              here ya go!
              hope it helps
              thanks for that, I will be checking for blocked air ducts tomorow.
              • srvctec
                • Oct 2009
                • 827
                The C258 doesn't even have a toner filter, though. Also, no air ducts since there is no toner filter to receive any toner (just confirmed on a C368 we have in the shop). So, not sure why it's included in those pdfs.
                • Scarekrow
                  • Feb 2012
                  • 80
                  Been to the machine today, they have done 400 colour copies since I last vacced out the machine, here are some pics of the inside.
                  IMG_20220211_135803.jpg: Upload of file failed.
                  • Scarekrow
                    • Feb 2012
                    • 80
                    There are air ducts the dev units press onto at the back, they are contianed into the drive unit, however theses didnt look blocked, but I vacced them out using a long tube vac attachment.
                    • srvctec
                      • Oct 2009
                      • 827
                      Guess I learned something today, then. I just pulled out a drum and there is no air ducts on those like there is on the 4/4e series. I wonder where the toner goes from the ducts since there is no toner filter.
                      • Scarekrow
                        • Feb 2012
                        • 80
                        I dont know that range you mentioned, however the ducts are on the top of the dev unit so you wont see them just by removing a drum, I would upload the photos I took on site if I could work out how to send them here.
                        • Scarekrow
                          • Feb 2012
                          • 80
                          Google drive link
                          IMG_20220211_135803.jpg - Google Drive
                          IMG_20220211_135827.jpg - Google Drive
