Konica 7035 "Replace Fuser" message
  • Lotar
    • 76
    Hello,
    I am working on a Konica 7035 and I have rebuilt the Fuser I am not sure how to reset the "Replace Fuser" message?
    I am also going to be Replacing the Developer and wanted to find out If there is a DV setup procedure? or is it just vacume out fill with new and go?
    Im new with Konica 7035 any help would be Wonderful.
    Thank you.
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    It's been awhile but I believe its 36 mode, counter reset, fixing counter.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • dogsbody
      • Jun 2007
      • 289
      Don't vac out the dev tank if you don't have an earthed vac - you can kill your TDS sensor.
      Developer is also in 36 mode, HV adjustment, back untill you find L-detect.
      The force will be with you always.
      • kiwitechnician
        • Dec 2008
        • 54
        Originally posted by Lotar
        Hello,
        Thank you.
        If you want to clear ,,the fuser message,, you have to be sure you replaced the fuser web.Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
        After repacing of developer go to 36=> HV adj. => Ldetection => Start.This action resets Developer counter as well. Don't do that with old developer only with the fresh one. The range should be between 65-70.
        You should reset PM count in 25 mode as well, 25 => PM reset(items 2) => and do'nt forget reset all particular counters in 25 => Parts counter (4)=> Fixed parts that you replaced. ( Feed tyres ...). In future you will have nice overview of parts used in the machine.
