Olivetti d-color MF304 (Bizhub C308)
  • tec966
    • Mar 2009
    • 40
    Can anyone help me about the problem in the attached file ?
    Dev unit k, drum unit k, Hight Voltage Unit and FRB board already replaced...
  • Gift
    • Mar 2011
    • 2447
    Re: Olivetti d-color MF304 (Bizhub C308)
    That diagonal pattern usually indicates developer drainage. Did you swap the dev unit first and without other parts - and was the problem gone for a while?
    If that was the case you probably have to change it again - a faulty drum unit or hv can cause this problem over a period of time.
    • tsbservice
      Field tech
      • 7926
      Look at the back of machine and make sure air ducts on the rear frame (inside the Main Drive Unit) are not blocked. ITB over life also should be changed.
