Any help on resetting the fuser unit on these models. Tried looking for fuse as per +351, but no joy.
Ineo+251 Bizhub C252 Fuser Reset
the unit is resettable with a 60ma fuse available from katun which can be wound round contacts in place of glass fuse . minolta have issued a warning about a fire hazard on the lifes of these units i.e dont reset.
p.s same fuse that comes with di251 pcu rebuild kitComment
It could be the HV contact if the fuse has not blown, check the fuse (once you have identified were it is) and follow the wiring to see were the contact for the fuse is, you should be able to check for continuity between these points. if there is no continuity it is normally the machine side contact may be bent away from the fuser contact.Comment
