Anyone know what kind of SODIMM the C258 series takes? I don't fancy spending silly money on a UK-211 when all it is is laptop memory.
C258 Memory Upgrade
Re: C258 Memory Upgrade
Any particular reason you want to upgrade memory? The additional memory is only used with the LK kits, and since it looks like you want to do this yourself, unplug it, pull the back off, and get the specs for the currently installed chip. E -
we got lk114 and the current ram is embeddedComment
I know the 2GB DDR3 type Ricoh "leftover DIMMs" for the MPC3004 are working fine in the 8 series.
Probably any 2GB nonECC 204pin S0DIMM should work. Go for the 1600mhz capable ones to be shure and buy one sample for testing before placing a big order.Comment
thanks yeah will try that and update the outcomeComment
are you in the US?
i might be able to help
Attached FilesWe know a thing or two because we've seen a thing or two.
The medication helps though...Comment
