AU-201H Driver For bizhub C227
  • asheer.singh
    • Jul 2023
    • 20
    I am looking for the AU-201H driver for a bizhub C227. Does anyone have a copy of this that they could please send through?
  • emujo2
    • Mar 2017
    • 1580
    Re: AU-201H Driver For bizhub C227
    FeliCa Idm or FeliCa Private?
    Adding...be sure you are clear here..There's a AU-201 and a AU205H, but no AU-201H
    • asheer.singh
      • Jul 2023
      • 20
      See attached pictures. This definitely says AU-201H on the unit? Will this not work with a bizhub C227?
      • emujo2
        • Mar 2017
        • 1580
        It will, what type of card will they be using?
        • asheer.singh
          • Jul 2023
          • 20
          HID Proximity Cards
          • usink
            • Feb 2023
            • 7
            used this driver Google Drive: Sign-in
            • asheer.singh
              • Jul 2023
              • 20
              • asheer.singh
                • Jul 2023
                • 20
                The service manual for install states:
                Before connecting the AU-201/AU-201S/AU-202H/OMNIKEY 5427CK (AU-205H)/SCL-010 card reader to the MFP, it is necessary to prepare an IC card information setting file with the loadable driver. To prepare this file, a tool is used for preparing the IC card information setting file for use in each card reader.
                Can this tool be downloaded to prepare the information setting file and loadable driver? Or do you only need the loadable driver for the AU-201H?
                • Synthohol
                  Certified Konica Expert
                  • 5740
                  i dont think it matters, there is no 201H on this side of the pond.
                  the 201 (no H) is a stripe reader, (the 205H (prox) is) that is what is referenced in your quote (Before connecting the AU-201/AU-201S/AU-202H/OMNIKEY 5427CK (AU-205H)/SCL-010)
                  do you have any written proof that the 201H will work on the 227? i cant find any.
