Electronic module for hp designjet 3800cp
  • das8165
    I am looking for a electronic module for a hp designjet 3800cp. Can anyone help , please reply soon as possible with price.
  • 10871087
    • Jan 2005
    • 1143
    "Electronic Module" is a pretty vague term. Can you be more specific or do you have a part number?
    • das8165
      RE: electronic module for hp designjet 3800cp
      You are absolutely right(should've explain more) I am not really a hp tech but The electronic module from what I understand is the main board and power supply with a fan. I am getting a 010035-0200000 code on the panel, the service manual says to replace the electronic module. I would think that replacing the main board would probably fix the problem, but I was just going by waht the manual says to make sure. Ever had this problem before ? Any help is surely appreciated
      • technogeek2000
        Hello Das8165, sorry to be getting into the thread so late. Do you still need that electronics module?
        Carl
        • das8165
          hp 3800cp electronic module
          yes, i still need it . I am getting error code 0100035. The troubleshooting guide suggest I replaced the module. I need it like yesterday
          • technogeek2000
            Hello,
            I thought that I might have the electronics module. However, from the manual I have found, it appears that the one you need is not the same as the one I have. Do you have the part number for the electronics module? Also, have you tried re-seating all of the electrical connectors attached to the electronics module? Sometimes that will take care of odd electronic problems.
