1. Enter the 36 mode.
2. "36 mode menu screen"
Press the [1. Process adjustment] key.
3. "Process adjustment mode menu screen"
For the process adjustment, there are the following
items provided:
[1. High voltage adjustment]
[2. Drum peculiarity adjustment]
[3. Sensor output adjustment]
[4. Exclusive paper setting]
[5. Recall standard data]
4. Press the key of an item you want to adjust.
5. Press the [PREVIOUS SCREEN] key to return
from each of the adjustment screen to the
"Process adjustment menu screen."
items provided:
3. "Process adjustment menu screen"
Press the [2. Drum peculiarity adjustment] key.
4. "Drum peculiarity adjustment menu screen"
For the drum peculiarity adjustment, the following
items are provided:
[1. Blade setting mode]
[2. Automatic drum potential adj.]
[3. Automatic gamma adjustment]
[4. LD bias adjustment]
[5. Automatic developer charge]
[6. L-detect initial auto. adj.]
[7. Initial drum rotation]
5. Press the key of an item you want to adjust.
6. Press the [PREVIOUS SCREEN] key to return
from each of the adjustment screens to the
"Drum peculiarity adjustment menu screen.
