The temp sensors usually cause this code but before you replace them, make sure you have the correct upper roller fitted. I chased this problem on a 420 for ages before I realised a previous tech had fitted a 500 roller!!
Hope this helps..
I had the same problem when web roller was finished.
But after I changed the web roller-code reappears .
So,check the web roller. If it's ok - change :FIXING SENSOR ASSY
50GA -5440
