c252 mainmotor
  • sairam
    • May 2009
    • 26
    c252 mainmotor
    hello friends,
    I got a PROBLEM WITH MAIN MOTOR in c252.code is c5102.so wht i have to do
  • Mercutio Norway
    • 11
    C252 Mainmotor Failure
    Sorry to be the bringer of bad news, but you have to replace the main motor. As I can remember it's about an hour or so work...
    You have to remove the main control board to get access to the engine.
    • sairam
      • May 2009
      • 26
      thanks
      thanks for u r sugettion.I cross cheaked with devoloping motor.then problem shifted therecode hase come that c2255.but c5201 code was gone
      as u told main motor has tobe replace.but is there any chance to repair main motor control board (its with main motor).
      • ni311
        • May 2008
        • 658
        How can you tell it is the control board faulty and not the motor? I never heard someone bothering fixing the motor, everyone is just replacing it, including me.
        Konica Minolta Error Codes - Explanations and Solutions
        • sairam
          • May 2009
          • 26
          252 mainmotor
          ok ,I will go through u r soltion .what will be the problem in the motor.just know deep.and any body can tell the cost of motor assembly
          • JSC
            Gimp
            • Dec 2006
            • 618
            Every time i have had this code ( 4 times ) its been down to the main motor ( m1 ) it takes about 45min to 1 hour to fit.
            The gene pool could use a little chlorine.
