Last paper jams bizhub 162
  • minolta35
    Trusted tech
    • Apr 2005
    • 87
    Last paper jams (not jam, machine stops when the last paper's end is on exit switch) when making multicopies.
    Same thing happens often making 1 copy.
    I change registration sensor with by-pass sensor.It still goes on...
    And same thing when making copies into by pass...
    Customer choosed A4R copying casette and by-pass.
    It is not happen every copy but 50%...
  • mrwho
    Major Asshole!
    • 4299
    If doesn't happen on every copy, the most probable cause is a stuck actuator that doesn't fall back to it's resting place in time. Check your actuator's for any binding actuator and, while you're at it, clean all your sensors.
    Mascan42
    Ibid
