7222 paper curl duplex a3 ?
  • fishleg
    • Mar 2009
    • 426
    We have a machine that has just been serviced but when you do a3 duplex the first side curls so much on the trailing edge that it will either get stuck in the fuser or as it comes back up to do the second side.
    It looks like the paper feed on the duplex is to late causing a delay thus stalling the trailing edge in the fuser causing it to curl. Maybe ive got it all backwards anyone else had one like this ?
    Is it even possible to change the duplex timing so it is a little faster that if it is that clutching at straws really.
    Thanks for any help.
