How to Restore Factory Defaults in Konica 7145
  • eurosears
    • Feb 2010
    • 80
    Hi,
    My dad was trying to fix my Konica 7145 and he ran in 47 mode code 93. Basically he reset the copier settings and I don't know what to enter to get it working again. Can someone please give me a list of all the things I need to enter and how to get this copier working again>? Thank you.
  • Imagetech
    • Feb 2010
    • 13
    Try this...it sounds like he did what we used to call a "Mind Meld" and restored only part of the settings. The other sections being reset should be all it needs. Give it a try and let me know if it works. If I come up with something else I'll post.
    Description
    How to reset the machine, initialize memory to factory defaults.
    Solution
    To reset memory to factory defaults, perform the following:
    1. Enter the 25 mode (power the machine ON, while pressing the 2 and 5 keys).
    2. Select Software SW.
    3. Using the up/down arrows, scroll to address 3-4 (All Memory Reset).
    4. Select OFF.
    5. Power the machine OFF.
    6. Enter the 47 mode (turn the machine ON, while pressing the 4 and 7 keys).
    7. Enter 9, 2, press the START key, press the STOP/CLEAR key.
    8. Enter 0, 9, 6, press the START key, press the STOP/CLEAR key.
    9. Enter 0, 9, 3, and press the START key.
    10. Power the machine OFF/ON.
    Note: When the memory board is initialized, all data is deleted.
    • eurosears
      • Feb 2010
      • 80
      I did exactly what you stated and now I have the following every time I turn on the copier (even if I go to mode 36 and do L detect): "Please adjust L detection". I am unable to do any copies.
      However, before doing what you mentioned when I was going to do L detect the value was 255, now its at 44. I should mention that my sensor on the developer is damaged (cracked) and will have to be replaced (this is why the value is below 60). However, before the factory reset even though it was damaged I was still able to do L detect and make copies once I entered the copy mode ( until the printer was turned off or jammed). SO what's with the "Please adjust L detection" even after L detect.
      Also, whenever I click on anything on the display I don't hear the sound (I was able to hear it before, is it turned off). Is the sound turned off as default.
      • Imagetech
        • Feb 2010
        • 13
        Sorry about that...I've honestly never seen the machine ask for an L-detection usually it just throws 26-3 codes. I have the Konica solutions on my other laptop and I'll be getting back to you shortly as to how to correct that problem. The key click sounds were probably defaulted off. Some machines come from the factory on some off...it's been so long since I've done an out of the box set up on a 7145 I can't remember how that was. Easy enough, though, you should be able to go into the key operator mode and turn it back on (just touch the Help key and there should be a tab at the bottom for key operator mode and once in there I believe it's under software switches). I'll be getting back to you shortly on the L-detect problem.
        • selig67
          • May 2008
          • 156
          yeah, I get the L detect also when re-setting.. you just need to replace the developer and run an L-detect, that should take care of the problem, unless the cracked sensor is going to give you some problems
          • eurosears
            • Feb 2010
            • 80
            Once you did the L detect in menu 36 did the message disappear and were you able to go into the copy mode ?
            Its wierd that I am unable to just do the L detect in menu 36 and go into the copy mode without having this message appear. I was able to do it before.
            • eurosears
              • Feb 2010
              • 80
              Selig67, once you turned off the copier and on and went to menu 36 and did the L-detect did it take care of it?
              • smiley
                • Aug 2008
                • 616
                hi guys go to 25 next sw look for 16-3 turn it 0 and off and on the machine.that note will disapeare.
                there is no glory without sacrifice
                • eurosears
                  • Feb 2010
                  • 80
                  That works great. Thank you. I don't even have to replace my damaged TDS.
                  Can you please tell me how to turn on the sound (so I can hear when I click on the buttons)?
                  • smiley
                    • Aug 2008
                    • 616
                    hold help button and power on look for memory switch.
                    • eurosears
                      • Feb 2010
                      • 80
                      It works now, thank you
                      • pepper38_cnd
                        Field Service Manager
                        • Aug 2005
                        • 1075
                        If you know you have a bad Toner Density Sensor, do yourself, your customer and your Dealership a big favor and replace it. Does F-26 ring a bell?
                        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                        Now into Ip TV KODI Boxes
                        • eurosears
                          • Feb 2010
                          • 80
                          I am not a dealer, I don't have any customers. The copier works fine with the damaged sensor so no reason to spend more money if the copier works fine. I will get it once I have a problem.
                          BTW you can turn off the F26-3 error, read above.
                          • fishleg
                            • Mar 2009
                            • 425
                            What does switch 16-3 actually do ? I know 3-7 turns the td sensor off but never heard of 16-3 before.
                            Cheers,
                            Mike
                            • eurosears
                              • Feb 2010
                              • 80
                              Well I have a cracked TDS sensor so after doing a Factory Reset of the copier I had a message that I needed to adjust the TDS sensor even after doing the L-detect.
                              The 16-3 took care of that message and, even better, now I don't have to do L-detect every time I get a jam or turn off/on the copier.
