bizhub 362 reboots mid copy run
  • KEVIN900
    Copier Ninja
    • Oct 2009
    • 200
    Please help a tech out. On my biz362, during a long copy run, the machine will inexplicably re-boot. The outlet is fine, Firmware is up to date. Help !
    Kevin900
  • BIG PAPA
    Da Boss
    • 234
    Does it throw an abort code, or just power off? When you say the outlet is fine, was it checked with a multi-meter or an actual power monitor? Have you witnessed this happening? Possibly poor contacts on one of the power switches?
    sigpic
    • KEVIN900
      Copier Ninja
      • Oct 2009
      • 200
      Thanks for the quick reply, BigPap. No abort codes, The outlet was checked with my multimeter, 116-118 volts range, .5 on ground, rising to 1Volt when fuser is on, I have witnessed this happening.
      Kevin900
      • BIG PAPA
        Da Boss
        • 234
        If you have access I would plug in a power monitor and leave it until this happens, then look at the reports, Sometimes hard to tell with a multimeter. Could be something else on the circuit that intermit with the copier causes a drop.
        sigpic
        • KEVIN900
          Copier Ninja
          • Oct 2009
          • 200
          Thanks BigPapa. I'll run with your fine suggestions and see how it goes.
          Kevin900
