F 35 1 code on konika 7022
  • claude1957
    • Mar 2010
    • 18
    anybody know what to do with it ???
    claude
  • Pinoy_Tech
    • Feb 2010
    • 47
    F35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it "zero". If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
    • aidil rashidi
      • Jun 2008
      • 33
      Check also BOTH of the heater lamp for sign of broken filament or discoloration. this usually meant faulty lamp.
      • claude1957
        • Mar 2010
        • 18
        l 35 1 on konica 7022
        I am sory about that but I made a mistake It wasen't a F 35 1 code but a F 36 1 code sory again.
        and thanks for your help
        claude
        • Pinoy_Tech
          • Feb 2010
          • 47
          Did you solved already? It is the same fusing error code but overheat poblem and the resetting is the same procedure. Similar problem with Thermistor abnormalities.
          • claude1957
            • Mar 2010
            • 18
            f 36 1 code on konica 7022
            Not yet I am trying to find the th1 in some place but no sucess yet. Trying to find the service book but no luck to but I let you know for sure
            thanks again
            claude
            • nxoxe
              No. Error code
              (decimal number)
              Classification KRDS
              Main code Sub code
              001 10-1 Communication error E0 00
              002 10-2 01
              003 — — 02
              004 18-1 Paper feed tray error 03
              005 18-2 04
              006 18-3 05
              007 18-4 06
              008 26-1 L detection error 07
              009 28-1 High voltage power
              error
              08
              010 28-2 09
              011 28-3 0A
              012 34-1 High fixing temperature
              abnormality
              0B
              013 34-2 0C
              014 35-1 Low fixing temperature
              abnormality
              0D
              015 35-2 0E
              016 35-3 0F
              017 35-4 10
              018 35-5 11
              019 35-6 Low fixing temperature
              abnormality
              E0 12
              020 35-7 13
              021 35-8 14
              022 35-9 15
              023 35-10 16
              024 36-1 Fixing sensor error 17
              025 36-2 18
              026 36-3 19
              027 — 1A
