i have got a minolta EP 3000 series copier which is basically given in the australian asian region, i got a major breakdown with the main fuse near the powersupply chord is getting lown even though the power supply is normal , i have another minolta copier and it is working well, can u advice me what should i do in a span of 15 minutes 4 fuses of 8 and 10 amps were blown the minute i put the power plug, i cheked my wiring in the office and its is well can u help me ASAP, thanks
minolta copier dead
ericvic13Tags: australia, breakdown, connections, connectors, copier, dead, even, help, minolta, off, one, power supply, powersupply, short, wiring
I'm not a Minolta tech but give this a try.
Pull ALL of the output connectors off the power supply and plug it in. If it blows the fuse, you have a dead PCB.
If it DOSEN'T blow the fuse, plug in one output connection untill it does blow the fuse. THAT will be were your short is.
If this is the main power supply, check the fuser lamp connections and wiring.
Hope this helps.
Parker
