ricoh fax1800L
  • toshiba
    • Dec 2006
    • 58
    ricoh fax1800L
    hi all
    in ricoh fax 1800L intermittent receiving pbm is found. telephone line is perfect. what can be the reason? how it can be rectified?
    suggestions please.
  • Techos
    • Jun 2025
    Originally posted by toshiba
    hi all
    suggestions please.
    Hi
    The best way to resolve a communication problem on a Ricoh Fax is to
    print first error report, then just watch wich error codes are the more
    frequent you will find in the service manual an answer for each error code.If your line is OK, you can disable V8/V34 and J big to,short preambule work to.
    • nokia88
      • Aug 2009
      • 72
      have you got service manual of 1800l ? First, check error code (service 03), if line signal is ok, try to perform:
      1) Cable equalizer
      2) reduce Modem speed (Rx &Tx)..
      then try to transmit & received fax...good luck
