What's does trouble code C-3201 on konica minolta bizhub C253?
C-3201 trouble code on konica minolta bizhub C253
From the resource:
C3201 Fusing motor failure to
turn
• The motor lock signal remains HIGH for a
predetermined continuous period of time
while the motor remains stationary.
That could be a stinker! Or a really bad fuser jam!
Reset by open/close front cover but only if your sure the fuser is clean/empty of jams!
Regards!
A. -
bizhub C203/C253/C353
PROBABLE CAUSES:
1. Failed DCPU and/or fuser motor (M5).
Check for 24V DC at DCPU CN10, pin 1. Replace DCPU if no 24V DC present at DCPU CN10, pin 1 (p/n A02E M400 01). If deemed necessary, replace
fuser motor M5 (p/n A02E M100 00).
2. Failed PRCB (PWB-MC).
Replace PRCB (p/n A02EH00106).
3.Binding fusing unit or possible failed fusing motor.
Prior to replacing the fusing motor (M5), please perform the following:
a. Confirm that the fusing motor CN79 is firmly seated.
b. Remove the fusing unit and ensure that the fuser rollers turn freely and are not restricting the rotation of the fusing motor.
c. Inspect and reseat CN34 on the PRCB which is the interface connector for the fusing motor (M5).
d. Replace the fusing motor (p/n A02E M100 00) as necessary.Comment
