bizhub 250 scan to folder
  • david ahn
    • 13
    I am a bizhub 250 user. i already set up the printing driver, which is very OK.
    I wonder bizhub 250 have a scan to folder(SMB) or scan to email funtion.
    Do i need something set up in the machine in order to use this function or
    These function is buit in the machine, so i can use without any additional kit.
    If i need the kit for thes functions, what do i need to do?
    Thank you.
  • Darren King
    copiertech
    • 652
    There is not an extra kit needed for this machine to scan. You just need to have the scan settings input into the machine
    Hope this helps
    Darren
    • alan.ward
      • 9
      Scan to FTP is the best and easiest to use. You can download the utility from the Konicaminolta site. After running the install program you just set up a folder on the root directory and browse to it with the setup utility. All you have to do after that is set up a one-touch button on the machine and direct it to "\" (root). You set up where to put the file in the setup utility. Keep authentication set for anonymous. I think the download comes with instructions also.
