Bizhub PRO 1050P
  • pierre
    • Mar 2008
    • 12
    Bizhub PRO 1050P
    hello all,i have SC23-17 error code, i need some advice to solve this problem,thanks
  • ni311
    • May 2008
    • 658
    Causes
    Leakage at the mixing section is detected. When the toner pump motor (M28) is operating, the toner remaining sensor /4 (PS34) detects the toner being provided in succession for 20 seconds.
    Estimated abnormal parts
    Toner pump motor (M28) / Air pump motor (M29) / Toner remaining sensor /4 (PS34)
    Note:
    When the code SC23-17 occurs, be sure to repair defective parts before setting the software DIPSW3-1 to 0. Setting the DIPSW3-1 to 0 without repairing defective parts may cause toner to overflow inside and outside of the machine.
    Konica Minolta Error Codes - Explanations and Solutions
    • pierre
      • Mar 2008
      • 12
      thanks ni311,
      i did check the Toner pump motor (M28) / Air pump motor (M29) / Toner remaining sensor /4 (PS34), and they work properly, but the error code still apper.
      is there any other advice?
      plz replay
      regardes
