Error messages in bizhub 420
  • aleksander
    • 378
    Anyone have any experience with "Error 5" and "Error 6" in bizhub 420? I'd tried to find it in Service Manual but I can't find it. Error appear when I ran TCR Adjustment after replacing Drum unit.
    Any information will appreciate.
    Thank you.
  • tech51
    • 846
    Ive not had it happen on the BZ420 range but on the 7145 range it was usually the sensor in the drum carriage that was either faulty or dirty. Might be worth swapping the sensor from the old unit and see what happens...
    Just looked it up Error 5 could be faulty TCR sensor (dev unit) Error 6 could be drum sensor or print control board. I would still try the drum sensor first..Cheers...
    • manuelcorrea
      • May 2009
      • 46
      Did you replace developer too or just drum unit? You do not have to run TCR adjustment if you only replaced drum unit.
      • aleksander
        • 378
        drum with developer unit. thanks
        • Downunder
          • Aug 2007
          • 174
          Thank you.
          Did you get a 2801 code as well?
          You might have to replace dev unit.
          • aleksander
            • 378
            No. That's a new Dev unit.
            • Downunder
              • Aug 2007
              • 174
              tech 51 may be right
              Clean sensor on drum unit, replace TCR sensor and then Print control Board. You will need to do firmware for print control board if it is new.
              • aleksander
                • 378
