yellow in 6501
  • levino
    • Jul 2009
    • 38
    [CQ] yellow in 6501
    Hi,
    IN my KM6501 yellow is not uniform
    I tried drum,developer,belt,charger and transfer rollers
    done the uneven density adj too
    no chance
    Pls help
    tanks in advance
    Levi
  • HORSE
    • Mar 2008
    • 186
    Laughing......
    • RRodgers
      • Jun 2009
      • 1947
      I didn't see you mention that you did the charge corona and the charge corona's on this box are know to not sit in there holders properly from manufacturing.
      Pull your charge corona out and look at the wire. They usually "fall off" the plastic parts that hold them in the center of the housing.
      • HORSE
        • Mar 2008
        • 186
        He did mention that he replaced the 'charger' along with all the other parts.
        Laughing......
        • RRodgers
          • Jun 2009
          • 1947
          Ahh... you are right... I was looking for corona when I scanned what he replace... LOL Still.. it's a known issue and I'd be willing to bet the new one is not set right.
          • HORSE
            • Mar 2008
            • 186
            Yeah but if it had been me I would have swapped the corona around with another colour before fitting a new one
            Laughing......
            • Stirton.M
              All things Konica Minolta
              • Oct 2009
              • 1804
              As Horse mentioned, more detail on what is wrong with the yellow is needed. A picture is worth a 1000 words. If you can, do a 53 halftone test page with the yellow and any other colour at a density of 150 each. This will make yellow stand out relative to the other colour and show any defects. Post that image so it is easier for us to visualized the problem.
              Following the discussion between RRodgers and Horse, on the extreme end of possibilities, the issue might be related to an uneven drum drive shaft....rotating in a wobble. Swap the yellow drum drive unit with the cyan (they are offset like that in the back). If it moves, there is your problem. If it doesn't move, you at least eliminated that area.
              "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
              ---Groucho Marx
              Please do not PM me for questions related to Konica Minolta hardware.
              I will not answer requests or questions there.
              Please ask in the KM forum for the benefit of others to see the question and give their input.
              • random
                Assumeing you are seeing this on DOT1.....
                Set test chart density to 80 and run test chart 53 alternate dip-sw 3-0 between 1 and 0. Does it improve or make it worse?
                • levino
                  • Jul 2009
                  • 38
                  Hi, tanks to all,
                  The uneven in the main scan only,I was tried in the dot1 in 53 test pattern with density 70.
                  Th the new charger replaced was swapped and tested Also I swapped the charger from another machine..AS per Horse i checked and confirmed that Yellow blotches are in the solid gray areas------.I done the density adjustment with yellow only.I can post 53 test pattern tomorrow.This machine run only 45k prints.
                  • HORSE
                    • Mar 2008
                    • 186
                    Laughing......
