Error code c-13c8 after new transfer belt fuse
  • GLENBO
    • May 2025
    [Error Code] Error code c-13c8 after new transfer belt fuse
    Hi all, my machine is down and hopefully someone can help. I got a message on my Bizhub C350 telling me to change the transfer belt. So I did some reading and changed the fuse in the transfer belt unit. When I reinstalled it, the machine came back with the error code c-13c8. Can someone tell me what this code is and how can I clear it?
  • albasoul06
    A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
    Change PWB-MC,.........................is the Control Board (PWB-MC)
    • GLENBO
      Thank you for the reply. I'm happy to report that it's alive! And I must admit that I trusted someone where you should always double check. I purchased the fuses from a source I normally don't use. Needless to say, he gave me the wrong fuses. I received 800ma instead of 80ma fuses. Once the correct fuse was in place, it fired right up. Again, thanks for your help.
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        I was just gonna mention to ensure your fuse is the correct value...that code is related to it not popping when it should. 1/16th Amp pico fuses.
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
