When feeding from tray 1, you can select 1 copy and it will make and complete that copy and then run another sheet of paper into the registration rollers showing jam j30-1 and showing sections 6 and 8 in display. Feed rollers are new, Replaced the feed clutch as well as one-way drive gear. The pickup lift solenoid is also fine and it actually holds the pick up roller away from the stack at rest. All other trays feed fine. Any suggestions?
Konica 7055 jams from tray 1 only
