Hi,
We've recently purchased a ColorForce 8050 from a print shop that went out of business and got it working again where it can make copies and stuff. I'm now trying to set it up so I can print to it from Windows. I know how to add network printers and install drivers and stuff, but I've never dealt with anything like this.
I've got the copier networked, and I can see it fine by pinging the IP address I assigned to it. Unfortunately, I'm a little lost on what I need to do to actually set it up for printing.
I've read online that this copier interfaces with a Fiery print controller. I'm not sure if this has an embedded IP-921 print controller, or if there even is one in there. I don't see in the menu where I can print out like a configuration sheet or something, and the web based interface that I get when putting the IP address in my browser doesn't really tell me anything either.
Assuming there is a Fiery print controller embedded, I've downloaded the Fiery Command WorkStation software and attempted to connect to the copier. It asks for a password, which, after looking online, the default password is either 0000, fiery.1, or Fiery.1. When I try any of these, it says "Unable to connect to (192.168.1.10). The server name or IP address may be invalid."
I'm not sure if this is not the correct software I'm supposed to be using to interface with the copier or what. I've also downloaded the drivers for the IP-921 and have attempted to just add it as a printer in Windows, but after sending a test page, it never prints and results in an error.
I guess what I need to know is,
1) How can I find out if there is a print controller built into that copier, and if not, does that mean that we can't print from Windows?
2) If there is a print controller, what software do I need in order to interface with it?
3) Is there a way to print out a configuration page through the menu on the copier?
