I know this use to work. A normal print job goes through. When I send a secure print with a simple ID/Password I get the failed to authenticate error. Anyone else seen this?
C253 Secure print jobs fail to authenticate
The ID and pass are simply 12345 for each. I do not have user accounts set up on this copier. Therefore I do not have authentication set up through PageScope. This was tested a few months ago and worked with out a hitch.Jamex Tech Support: Saving the world one phone call at a time.Comment
If I remember correctly this is the procedure I used.
Select secure print from print driver. I give the print job an ID and a password before I click print.
At copier touch the use document tab and select Secure Print User box.
At that point I am prompted for ID and password entered before I sent the print job.
When the correct ID/Password are entered the Job shows up on the job list and you select it and print it.
Now when I input the ID and password entered before I sent the print job (12345 for each) I get the "Failed to authenticate" message.Jamex Tech Support: Saving the world one phone call at a time.Comment
SECURE PRINT : Secure Print allows security to be imposed upon a document to be sent to the bizhubfor printing. The document will be “printed” to a
secure User Box and cannot be accessed, printed, or even viewed without first entering its authentication data at the MFP. Secure Print is a very powerful
feature as it allows security control of a document “on the fly”. The security data is imposed on the document in the print driver as a one-time function that
applies only to that specific printing of that specific document at that specific time. No prior programming is required to use Secure Print.
APPLICATIONS : The end user has a document prepared and wants to print the document to the bizhub, however, they do not plan on retrieving the
document.Comment
How to delete a secure print document without printing the document.
Solution
To delete a secure print document without printing the document, perform the following:
1. Press the User Box key.
2. Touch [File Document] on the touchscreen.
3. Touch [System User Box] on the touchscreen.
4. Touch [Secure Print User Box] on the touchscreen.
5. Touch [OK] on the touchscreen.
6. Input the ID for the secure print document stored on the machine.
7. Touch [OK] on the touchscreen.
8. Input the password for the secure print document stored on the machine.
9. Touch [OK] on the touchscreen.
10. Highlight the desired secure print document to be deleted.
11. Touch [Delete] on the touchscreen.
12. Touch [Yes] on the touchscreen.
13. Touch [OK] on the touchscreen.
14. Press the Copy key.Comment
Before I get to Chromatik's list:
1. Click print.
2. Click properties.
3. Select general tab.
4. Select secure print from the pull down.
5. Fill in the user data ID/Pass (12345 for both)
6. Click Print and go to step one of Chromatik's list.
When I hit step 8. It fails to authenticate.
Kon-Min Support recommended format HDD. I'll post back if it works.Jamex Tech Support: Saving the world one phone call at a time.Comment
I understand, just post this list to expand, maybe as you say the HD is corrupt to some file that contains the same ID and pass different or the other way around, but well check out the options for printing secure in the manual.
Service & Support | Konica Minolta Business Solutions, U.S.A., Inc.
Attached FilesLast edited by Chromatik; 08-31-2010, 06:44 PM.Comment
Drivers are the same as before. HDD format did not correct the issue.
While I was away from the copier another Tech re-initialized and it seems to be working again.
I wish I new what setting caused this in the first place.Jamex Tech Support: Saving the world one phone call at a time.Comment
http://kmbs.konicaminolta.us/content...UserManual.pdf
Just a follow up. Konica Minolta Tech support told me this was caused by a corrupt user box.Jamex Tech Support: Saving the world one phone call at a time.Comment
